EMC Unity Performance Data Collector Problem on STOR2RRD 2.70
I have update our STOR2RRD to 2.70 recently. After update, we faced with gap on EMC Unity data.
As I checked the below errors on /home/lpar2rrd/stor2rrd/logs/error.log-EMC-UNITY-XXX:
Now, performance data are collecting for EMC Unity but there is still an error:
Sat Feb 22 14:40:08 2020: Cannot save data, System UUID for EMC-UNITY-XXX does not exists! /home/lpar2rrd/stor2rrd/bin/LoadConf.pm:8659
I guess, there is need to release a patch or update for resolving the above issue.
Global symbol "$port_wwn" requires explicit package name at /home/lpar2rrd/stor2rrd/bin/unityperf.pl line 2210.
Global symbol "$port_wwn" requires explicit package name at /home/lpar2rrd/stor2rrd/bin/unityperf.pl line 2211.
Execution of /home/lpar2rrd/stor2rrd/bin/unityperf.pl aborted due to compilation errors.
After checking the unityperf.pl, I have added the below line:
my $port_wwn = "";
The previous codes are as follows:
my $port_wwn = "";
if ( exists $data{PERF}{$timestamp}{PORT}{FC} ) {
foreach my $port_id ( keys( %{ $data{PERF}{$timestamp}{PORT}{FC} } ) ) {
if ( exists $data{PORT}{FC}{$port_id}{WWN} ) { $port_wwn = $data{PORT}{FC}{$port_id}{WWN}; }
print CONF "$port_id,$port_wwn\n";
yep, there was a bug for UnityUse this hot fixGunzip it and copy to /home/stor2rrd/stor2rrd/bin (755, stor2rrd owner)-rwxr-xr-x 1 stor2rrd stor2rrd 96947 Feb 22 10:01 unityperf.plIf your web browser gunzips it automatically then just rename it: mv unityperf.pl.gz unityperf.pl
It should be ok after deploying that file. Let us know, thanks.
regarding second issue:Sat Feb 22 14:40:08 2020: Cannot save data, System UUID for EMC-UNITY-XXX does not exists! /home/lpar2rrd/stor2rrd/bin/LoadConf.pm:8659
Can you try config_check.sh against your Unity? There should be listed "System UUID" like here:cd /home/stor2rrd/stor2rrd # or where is your STOR2RRD working dir ./bin/config_check.sh EMC-Unity
STORAGE: EMC-Unity: UNITY
TCP connection to "xxx" on port "443" is ok
/usr/bin/uemcli -d xxx -u lpar2rrd -p XXX -noHeader /sys/general show -detail
1: System name = EMC-Unity
Model = UnityVSA
Platform type = EMC Storage System
System UUID = 420FFE1D-0234-FD02-976E-9217DC6135ED
License activation key = ELMEUV0716HN0K
Product serial number = VIRT162859DQXZ
Health state = OK (5)
Health details = "The system is operating normally."
connection ok -
Hi, thank for patch. Is there any other changes except the below?
my $port_wwn = "";
Also second issue still exists and there was no System UUID. Here is the output of config check:=========================STORAGE: EMC-UNITY-209: UNITY=========================TCP connection to "X.X.X.X" on port "443" is ok/usr/bin/uemcli -d X.X.X.X -u lpar2rrd -p XXX -noHeader /sys/general show -detail1: System name = Unity-XXXModel = Unity 400Platform type = EMC Storage SystemUUID base = 0Product serial number = CKM00XXXXXXXXXAuto failback = onHealth state = OK (5)Health details = "The system is operating normally."Power (Present) = 1361 wattsPower (Rolling Average) = 1362 wattsSupported SP upgrades = SP500, SP600connection ok
1. No, there was just one missing line, but on a different line then you had.
2. What is a firmware version of that Unity?/usr/bin/uemcli -d X.X.X.X -u lpar2rrd -p XXX -noHeader /sys/soft/ver -type installed show
here is a fix for the second issue:Gunzip it and copy to /home/stor2rrd/stor2rrd/bin (755, stor2rrd owner)-rwxr-xr-x 1 stor2rrd stor2rrd 456768 Feb 23 10:33 LoadConf.pmIf your web browser gunzips it automatically then just rename it: mv LoadConf.pm.gz LoadConf.pm
Error message "Cannot save data, System UUID..." shouldn't appear again.
Pls let us know a firmware version as i asked above, we would like to know it for our notes.
Thanks. -
The firmware versions are 5.x and 4.x, all versions had same problem.
