issue with svc
Can't get svc to work with stor2rrd.
stor2rrd version 2.61
svc firmware - 8.3.0.1
Wed Jan 29 17:15:03 2020 - ERROR - svcconfig.pl: Remote Command: svcinfo lssystem -delim : failed. - Return code: 1
Can't use string ("1") as a HASH ref while "strict refs" in use at /home/stor2rrd/stor2rrd/bin/svcconfig.pl line 275.
Unable to connect to remote machineunable to establish master SSH connection: master process exited unexpectedlyopenssh_pipe_out failed: unable to establish master SSH connection: master process exited unexpectedly/home/stor2rrd/stor2rrd/bin/svc_stor_load.sh: 2020-01-29_17:20 : Command svcconfig.pl ends with return code 2
Hi,is the connection test working?su - stor2rrd (lpar2rrd on the virtual appliance)cd /home/stor2rrd/stor2rrd./bin/config_check.sh <storage alias>
./bin/config_check.sh cluster-rbo-kt=========================STORAGE: cluster-rbo-kt: SWIZ : sample rate: 300 seconds=========================TCP connection to "10.99.255.122" on port "22" is okssh -o ConnectTimeout=80 -o StrictHostKeyChecking=no -o PreferredAuthentications=publickey -o SendEnv=no stor2rrd@10.99.255.122 "lscurrentuser"connection ok
Hi,try this fix
https://www.stor2rrd.com/download/load_svcperf.sh.gz
-rwxrwxr-x 1 stor2rrd stor2rrd 5692 Jan 28 16:11 load_svcperf.sh
Gunzip it and copy to /home/stor2rrd/stor2rrd (755, stor2rrd owner)
If your web browser gunzips it automatically then just rename it: mv load_svcperf.sh.gz load_svcperf.sh
Assure that file size is the same as on above example
When you are on AIX then change first line in the script to:
#!/bin/ksh
Let it run for 30-60 minutes, can you see data now?
Yes, this fixed the issue. Thank you.
