Example for VOLUME in the alias.cfg
How to do alias for VOLUME ?
I tried this:
VOLUME:VSP-km3:006021:vgdados02
VOLUME:VSP-km3:00:60:21:vgdados02
VOLUME:VSP-km3:00\:60\:21:vgdados02
Nothing worked
Thks
I tried this:
Nothing worked
Thks
what is your volume name? 006021 or 00:60:21.
If it is VSP then name with ":" I suppose.
Let us test it, colon might cause a problem. I will let you know. -
Any workaround for this, I have the same problem with VSP-G200 - fx a volume named
00:01:43
cheers - Thor
This is working:
VOLUME:HDS-VSP-G600:00\:08\:01:test_alias1
VOLUME:HDS-VSP-G600:00\:06\:0A:test_alias2
Have you run this after that to apply the change immediatelly?
./load.sh html
yep, that worked, thanks Pavel.
