Problem with LPAR configured with passiv WLM
after upgrade to lpar2rrd 6.02 and lpar2rrd-agent 6.01i run into problems.
Two AIX LPARs are configured with passive WLM. This LPARs had after upgrade only send ones data to the lpar2rr server.
Then they fill up the /var filesystem.
Is there any known issue with lpar2rrd and WLM in V6.02?
I had comment out the crontab jobs at agent side. Here is what happens when i start the agent with -d flag.
At server side this is logged in error.log-daemon
v2db02.lpar2rrd # /usr/bin/perl /opt/lpar2rrd-agent/lpar2rrd-agent.pl -d lpar2rrd-rz1
LPAR2RRD agent version:6.01-0
<snip>
Agent send : yes : forced by -d
Agent send slp: sending wait: 9
OS/HMC agent working for server: lpar2rrd-rz1
store file for sending is /var/tmp/lpar2rrd-agent-lpar2rrd-rz1-lpar2rrd.txt
Tue Jun 25 08:37:04 2019: wrong server response: agent_time:1560945060 : recv_time: :
Tue Jun 25 08:37:04 2019: Error: Not all data has been sent out, refused line: 8408-E8E*1234567:v2db02:13:1560945060:Wed Jun 19 13:51:00 2019 version 6.01-0:3724000000|8:v2db02:0::mem:::25165824:24337552:828272:19829064:0:2345684:pgs:::0:0:7168:1:::lan:en0:192.168.2.6:49461482084212:8113849412151:43661912638:28546913825:::cpu:::0:10:29:0:::san:fcs0:0xC0507609B4E6001A:109933106491344:7859374059840:10667066152:614558976:::san:fcs1:0xC0507609B4E6001C:109938476123413:7857088829200:10641628626:614073144:::san:fcs2:0xC0507609B4E6001E:109925097604425:7859331925280:10637837044:614504076:::san:fcs3:0xC0507609B4E60020:109932498290719:7855272237360:10638242030:614099229:::san_resp:fcs0::0.5:0.8:::::san_resp:fcs1::0.5:0.8:::::san_resp:fcs2::0.5:0.8:::::san_resp:fcs3::0.5:0.8:::::wlm:Unclassified:0.00:7:0.00:sup::::wlm:Unmanaged:0.00:0:0.00:sup::::wlm:Default:14.18:8466:0.00:sup::::wlm:Shared:0.00:243:0.00:sup::::wlm:System:10.37:4327:0.00:sup::::wlm:oninit:7.97:7345:0.00:sup::::wlm:oninit.Default:0.00:0:U:sub::::wlm:oninit.Shared:0.00:0:U:sub::::wlm:oninit.basis_at:5.02:2843:U:sub::::wlm:oninit.db02basis:94.98:4501:U:sub::::wlm:oninit.neptun:0.00:0:U:sub::::wlm:oninit.db02barm:0.00:0:U:sub::::wlm:oninit.barm:0.00:0:U:sub::::wlm:oninit.basis:0.00:0:U:sub::::wlm:oninit.jupiter:0.00:0:U:sub::::wlm:TOTAL:32.52:20388:0.00:sup::: /opt/lpar2rrd-agent/lpar2rrd-agent.pl:3639
substr outside of string at /app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl line 2453.
Use of uninitialized value $name_under_wrkdir in split at /app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl line 2456.
Use of uninitialized value $server in concatenation (.) or string at /app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl line 2460.
Use of uninitialized value $name_under_hmc in concatenation (.) or string at /app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl line 2474.
Tue Jun 25 08:36:48 2019: Cannot link :/app/lpar2rrd/lpar2rrd/data//8408-E8E*1234567/ : No such file or directory/app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl:2486 : No such file or directory
Tue Jun 25 08:36:48 2019: Cannot link :/app/lpar2rrd/lpar2rrd/data//oVirt/ : No such file or directory/app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl:2486 : No such file or directory
Tue Jun 25 08:36:48 2019: Cannot link :/app/lpar2rrd/lpar2rrd/data//RZ1_AIX059/ : No such file or directory/app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl:2486 : No such file or directory
Tue Jun 25 08:36:48 2019: Cannot link :/app/lpar2rrd/lpar2rrd/data//RZ2_AIX060/ : No such file or directory/app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl:2486 : No such file or directory
Tue Jun 25 08:36:48 2019: Cannot link :/app/lpar2rrd/lpar2rrd/data//XEN_iostats/ : No such file or directory/app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl:2486 : No such file or directory
Use of uninitialized value $RRDp::error_mode in string eq at /usr/lib64/perl5/vendor_perl/RRDp.pm line 168.
Tue Jun 25 08:36:48 2019: Client communication failed - client: (192.168.2.6): ERROR: opening '': No such file or directory at /app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl line 1039.
Any help would be appreciated .. :-)
Hi,what is your lpar2rrd server version?
Hi Pavel
LPAR2RRD version 6.02 LPAR2RRD edition free OS info Linux Perl version This is perl 5, version 16, subversion 3 (v5.16.3) built for x86_64-linux-thread-multi Web server info Apache/2.4.6 (Red Hat Enterprise Linux) RRDTOOL version 1.4.8 RRDp version 1.4008
v2db02# rpm -q lpar2rrd-agentlpar2rrd-agent-6.01-0
Some Info to WLM: We use ist "active", not "Passive" as i wrote first.
We create a WLM superclass oninit with subclasses basis_at, db02basis, neptun, jupiter.
I tried some kind of debugging to cloned lpar2rrd server that had no v6.01 agent data loaded to simulate the first send from v6.01 agent to v6.02 server.
Here is what is logged to daemon.out, maybe it will help youcreating wlm-Unclassified.mmmTue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unclassified.mmm$name_under_wrkdir ,8408-E8E*1234567/rz1hmc1/v2db02/wlm.col,$server 8408-E8E*1234567$hmc rz1hmc1 $name_under_hmc v2db02/wlm.colTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unclassified.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unclassified.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unclassified.mmm : 119 : wlm000 : wlm 119 : 1561461319:7:0.00:supcreating wlm-Unmanaged.mmmTue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unmanaged.mmmTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unmanaged.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unmanaged.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Unmanaged.mmm : 128 : wlm000 : wlm 128 : 1561461319:0:0.00:supcreating wlm-Default.mmmTue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Default.mmmTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Default.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Default.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Default.mmm : 137 : wlm000 : wlm 137 : 1561461319:18:0.00:supcreating wlm-Shared.mmmTue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Shared.mmmTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Shared.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Shared.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-Shared.mmm : 146 : wlm000 : wlm 146 : 1561461319:240:0.00:supcreating wlm-System.mmmTue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-System.mmmTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-System.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-System.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-System.mmm : 155 : wlm000 : wlm 155 : 1561461319:4557:0.02:supcreating wlm-oninit.mmmTue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-oninit.mmmTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-oninit.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02 - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-oninit.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/wlm-oninit.mmm : 164 : wlm000 : wlm 164 : 1561461319:15788:0.00:supcreating wlm-oninit.Default.mmmTue Jun 25 13:15:54 2019: mkdir : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/Tue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/wlm-oninit.Default.mmm$name_under_wrkdir ,8408-E8E*1234567/rz1hmc1/v2db02/oninit/wlm.col,$server 8408-E8E*1234567$hmc rz1hmc1 $name_under_hmc v2db02/oninit/wlm.colTue Jun 25 13:15:34 2019: Updating 2 : 8408-E8E*1234567:v2db02/oninit - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/wlm-oninit.Default.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: Updating 4 : 8408-E8E*1234567:v2db02/oninit - /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/wlm-oninit.Default.mmm - last_rec: 1560344100Tue Jun 25 13:15:34 2019: case struc : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/wlm-oninit.Default.mmm : 173 : wlm000 : wlm 173 : 1561461319:0:U:subcreating wlm-oninit.Shared.mmmTue Jun 25 13:15:54 2019: mkdir : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/oninit/Tue Jun 25 13:15:54 2019: RRD create : /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit/oninit/wlm-oninit.Shared.mmm$name_under_wrkdir ,,$server $hmc $name_under_hmc$base_file_link /app/lpar2rrd/lpar2rrd/dataTue Jun 25 13:15:54 2019: hard link : --> /app/lpar2rrd/lpar2rrd/data//8408-E8E*1234567/Tue Jun 25 13:15:54 2019: Cannot link :/app/lpar2rrd/lpar2rrd/data//8408-E8E*1234567/ : No such file or directory/app/lpar2rrd/lpar2rrd/bin/lpar2rrd-daemon.pl:2486 : No such file or directory -
Hello Joerg,
update LPAR2RRD to new version: https://www.lpar2rrd.com/download/lpar2rrd-6.02-24.tar
after that remove this directory: /app/lpar2rrd/lpar2rrd/data/8408-E8E*1234567/rz1hmc1/v2db02/oninit
Hello jihampl,
thanks a lot for your quick response. I had installed V6.02-24 yesterday.
After deleting all /var/tmp/lpar2rrd* files at client side every think seems to be OK.
WLM information is send to LPAR2RRD server and shown in GUI.
Again, thank you very much for your support.
Best regards
Joerg
