LPAR2RRD : IBM Power System Configuration : New (Alias) button not working :
Hi,try Ctr-F5 to refresh the page, or other browser.
Hello Pavel
tried aleady. Still same issue. -
Hi,please try to check Firefox browser console for errors:
Press [F12], then click on the "Console" tab.
If you don't see any errors try reloading the page again, the error may be generated when the page loads. The console will provide you with the error type, the location of the error and the line numberYou should see errors in red, pls screenshot.
Hello Pavel
I'm using chrome. No error reported.
Please note that I'm not using apache which comes with os. I've installed apache in custom location and using it.
Please find console message. No new lines generated when I click on 'New'
Hi,cd/home/lpar2rrd/lpar2rrdls -ld etc etc/web_configls -l etc/web_configAnything related in Apache error_log (somewhere in /var usually)?
Hello PavelI'm away from my desk now. Will respond to you once I get back.
Hi Pavel
Please find requested info belowlpar2rrd]$ ls -ld etc etc/web_configdrwxr-xr-x. 4 lpar2rrd lpar2rrd 4096 May 29 14:34 etcdrwxrwxrwx. 2 lpar2rrd lpar2rrd 4096 Jun 20 14:36 etc/web_configlpar2rrd]$ ls -l etc/web_configtotal 16-rw-rw-rw-. 1 webadmin webadmin 1467 Jun 20 14:32 alerting.cfg-rw-rw-rw-. 1 webadmin webadmin 0 Jun 20 14:00 custom_groups.cfg-rw-rw-rw-. 1 lpar2rrd lpar2rrd 0 May 29 13:44 hosts.json-rw-rw-rw-. 1 lpar2rrd lpar2rrd 44 May 24 17:34 htusers.cfg-rw-rw-rw-. 1 webadmin webadmin 232 Jun 20 14:00 reporter.json-rw-r--r--. 1 lpar2rrd lpar2rrd 940 May 24 17:44 users.json
httpd error_log from today[Mon Jun 24 09:42:09.939981 2019] [ssl:warn] [pid 11357:tid 47694190477952] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name[Mon Jun 24 09:42:09.947840 2019] [ssl:warn] [pid 11358:tid 47694190477952] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name[Mon Jun 24 09:42:09.949010 2019] [mpm_event:notice] [pid 11358:tid 47694190477952] AH00489: Apache/2.4.39 (Unix) OpenSSL/1.0.2k-fips configured -- resuming normal operations[Mon Jun 24 09:42:09.949039 2019] [core:notice] [pid 11358:tid 47694190477952] AH00094: Command line: '/app/httpd//bin/httpd' -
Hi,under root:chown webadmin etc/web_config/*and try "new" buton again ...
Hello Pavellpar2rrd]# ls -l etc/web_config/total 16-rw-rw-rw-. 1 webadmin webadmin 1467 Jun 20 14:32 alerting.cfg-rw-rw-rw-. 1 webadmin webadmin 0 Jun 20 14:00 custom_groups.cfg-rw-rw-rw-. 1 webadmin lpar2rrd 0 May 29 13:44 hosts.json-rw-rw-rw-. 1 webadmin lpar2rrd 44 May 24 17:34 htusers.cfg-rw-rw-rw-. 1 webadmin webadmin 232 Jun 20 14:00 reporter.json-rw-r--r--. 1 webadmin lpar2rrd 940 May 24 17:44 users.json
Changed permissions. Still 'new' button is not working. -
Hi,remove hosts.jsonis that working now?
Hello Pavel
Thanks. It is working after removing hosts.json
