Order of storage systems in nagivation
Hi,what order exactly? it is alfabetically sorted
you are right. It is by chance that in our environment the alpahbetical order matches the order the systems were added.
Is there a custom sort way or do I have to change the name of the systems to change the order?
it is not customizable, change alias (rename it).
Many Thanks Pavel!
