LPAR2RRD problems post XCP‑NG 8.3 upgrade
Problems occurred with generating LPAR2RRD graphs after the XCP‑NG upgrade from 8.2 to 8.3.
I also updated LPAR2RRD to version 8.05
But, after run /var/lpar2rrd$ ./load_xenserver.sh command:
I have a problem:
mon:/var/lpar2rrd$ ./load_xenserver.sh
load_xenserver.sh : start
xen-xapi2json.pl : collect data from XAPI, Fri Oct 17 16:16:18 EEST 2025
data collection : done successfully, Fri Oct 17 16:16:19 2025
xen-json2rrd.pl : push data to rrd, Fri Oct 17 16:16:19 EEST 2025
RRDp version: 1.7002
RRDtool version: 1.7.2
xen-json2rrd.pl finish : status 0
xen-cleanup.pl : already ran today, skip
An error occured in lpar2rrd, check /var/lpar2rrd/logs/error.log-xen and output of load.sh
$ tail -42 /var/lpar2rrd/logs/error.log-xen
XML parsing error:
not well-formed (invalid token) at line 1, column 0, byte 0 at /usr/lib/x86_64-linux-gnu/perl5/5.36/XML/Parser.pm line 187.
XML::Simple called at /var/lpar2rrd/bin/xen-xapi2json.pl line 152.
XML parsing error. Trying to recover XML with xmllint at /var/lpar2rrd/bin/xen-xapi2json.pl line 155.
/var/lpar2rrd/data/XEN_iostats/xml/rrd_updates_xen05_1760705779.xml:1: parser error : Start tag expected, '<' not found
{"meta":{"start":"1760705820","step":"60","end":"1760706960","rows":"20","column
Fri Oct 17 16:16:19 2025: XML parsing error:
no element found at line 2, column 0, byte 22 at /usr/lib/x86_64-linux-gnu/perl5/5.36/XML/Parser.pm line 187.
XML::Simple called at /var/lpar2rrd/bin/xen-xapi2json.pl line 159.
/var/lpar2rrd/bin/xen-xapi2json.pl:163 file: /var/lpar2rrd/data/XEN_iostats/xml/rrd_updates_xen05_1760705779.xml at /var/lpar2rrd/bin/xen-xapi2json.pl line 163.
XML parsing error: File: /var/lpar2rrd/data/XEN_iostats/xml/rrd_updates_xen05_1760705779.xml at /var/lpar2rrd/bin/xen-xapi2json.pl line 164.
Fri Oct 17 16:16:19 2025: error while connecting to xen05, error: error: invalid XML
: /var/lpar2rrd/bin/xen-xapi2json.pl:75 at /var/lpar2rrd/bin/xen-xapi2json.pl line 75.
XML parsing error:
/var/lpar2rrd/data/XEN_iostats/xml/rrd_updates_xen06_1760705779.xml:1: parser error : Start tag expected, '<' not found
/var/lpar2rrd/bin/xen-xapi2json.pl:163 file: /var/lpar2rrd/data/XEN_iostats/xml/rrd_updates_xen07_1760705779.xml at /var/lpar2rrd/bin/xen-xapi2json.pl line 163.
XML parsing error: File: /var/lpar2rrd/data/XEN_iostats/xml/rrd_updates_xen07_1760705779.xml at /var/lpar2rrd/bin/xen-xapi2json.pl line 164.
Fri Oct 17 16:16:19 2025: error while connecting to xen07, error: error: invalid XML
date end all : Fri Oct 17 16:16:19 EEST 2025
Does anyone know anything about this?
end us logs.
under lpar2rrd user:
cd `cat ~/.lpar2rrd_home`
Hello, I’ve just sent it.
- 138 XorMon
- 180 LPAR2RRD
