Xormon and IBM CMC connection issue
I'm trying to use Xormon to monitor the Power infrastructure.
Connection to the HMC works however I don't manage to connect to the CMC website.
LPAR2RRD and Xormon (Podman version) are running on the same server.
I got a "connection failed for CMC". I put exactly the same settings like the ones on lpar2rrd.
What I observed, it tries to reach the API V1 https://xxxxxxxx/api/public/v1/ep/inventory/tags instead of v2.
Thank for your help !
Xormon version : 1.8.1 on Podman
Hi Gael,
send us Xormon logs, please:
UI --> settings --> Logs --> support logs: follow the form
Send us generated file via https://upload.xormon.com
Note a reference.
If you use LPAR2RRD, then send us these logs as well:
under lpar2rrd user: cd `cat ~/.lpar2rrd_home` tar cvhf logs.tar logs tmp/*txt tmp/*json gzip -9 logs.tar
Hi Gael,
thank you for logs.
1. download and apply the patch:
https://download.xormon.com/patch/1.8.17-4-gde642/CMC_COLLECT.pm.gz
Gunzip it and copy into the container:
sudo docker cp CMC_COLLECT.pm xormon:/app/server-nest/microservices/power/
2. restart container:
sudo docker restart xormon
Then let Xormon run for 2 hours and send us logs again.
Thanks.
It works now, there was a typo on the password.
Thank again for your support !
