IBM FlashSystem 9500 Storage does not display graphics
Hello everybody,
I recently installed Xormon NG and configured my IBM FlashSystem V9500 Storages.
Connection tests work perfectly.
The same settings used in Xormon NG are used in Stor2RRD and in this second the collection works perfectly, however in Xormon NG the graphics are blank.
I apologize that my English may be a little confusing, as I used Google Translator
Thank you in advance for the help.
Hi Rafael,
send us
- screenshot from the Xormon UI
- logs
UI --> settings --> Logs --> support logs: follow the form
Send us generated file via https://upload.xormon.com
Note a reference pls.
Pavel, thanks again,
The log file was sent and some screenshots too.
If you need some more images just ask.
I configured my vCenter in Xormon NG and it brought the VM data, however, I missed the Host information.
Would you prefer that I open a new topic or do we deal with this here?
switch to email pls, you know our emails :)
I am seeing the same issue on 1.60 and 1.70.
2x 2076-124 - Xormon-NG no graphs
same devices connected to Xormon (original) and I have no issues with Graphs.
Matthew
send us a screenshot and logs
i have the same issue with a IBM storage FS7200 witch xormon NG, i can´t see the graphics, i connected 2 ibm storwize without a problem.
but the fs7200 connect correct pass al the test connection and show information about storage, but not the statistics
can you help me? please.
send us logs and a few screenshots to document the issue (attach even screenshot from storage connection test)
I have the same issue with an IBM Storage FlashSystem 5300 with XorMon 2.0.
I was able to connect 2 IBM FlashSystem without issue but no statistics is shown.
Can I get some help please ?
send us logs:
UI --> (Help -->) Logs --> Support Log --> Export All Logs: follow the form
upgrade to the latest version 2.0.11 it should help. There is another issue with the SAN REST API, which the new version should also fix.
Thank you Karel, the upgrade solved my issue.
Best regards
