*.rrm does not exists /home/lpar2rrd/lpar2rrd/bin/detail-graph-cgi.pl:7670
try to upgrade to this version, let us know if the problem persists
https://www.lpar2rrd.com/download-temp/lpar2rrd-7.92-4.tar
upgrade docu: https://lpar2rrd.com/upgrade.php
It is only occurring in one IBM power supply, the others report normally. Should I update the LPAR2RRD server? or the LPAR agent?
The update is performed but now it stopped reporting all the CPUs on the dashboard for the power ones, and the box still does not update graphics to date
can you upgrade once more to this version?
https://www.lpar2rrd.com/download-temp/lpar2rrd-7.92-5.tar
If no data in next 1 - 2 hours then send us logs
- 130 XorMon
