Huawei Ocean Stor issue
I deployed Xormon-NG to plan the replacement of Stor2rrd and Lpar2rrd.
Four Huawei Ocean Stor device has no value. Both 5300 and both 6000.
No error for 5000 and OceanProtect x8000
In the log ~/xormon-ng/server-nest/logs/oceanstor-error.log, I found this :
2024-08-13 11:35:02: [OceanStor-Device] No data found for cmd performace_statistic/cur_statistic_data?CMO_STATISTIC_UUID=216:0&CMO_STATISTIC_DATA_ID_LIST=22,25,28,370,384,385,23,26,182,232,233,523,524,525,511,770,771,805,806,807 description : Invalid performance indicator IDs exist in the specified performance indicator list. error_code : 1073951268
2024-08-13 11:35:02: [OceanStor-Device] No data found for cmd performace_statistic/cur_statistic_data?CMO_STATISTIC_UUID=216:3&CMO_STATISTIC_DATA_ID_LIST=22,25,28,370,384,385,23,26,182,232,233,523,524,525,511,770,771,805,806,807 description : Invalid performance indicator IDs exist in the specified performance indicator list. error_code : 1073951268
2024-08-13 11:35:02: [OceanStor-Device] API command storagepool_data_info/0 failed
2024-08-13 11:35:02: [OceanStor-Device] {"data":{},"error":{"code":-1,"description":"The operation fails.","suggestion":"Try again. If the problem persists, contact technical support engineers."}}Can't use string ("") as a HASH ref while "strict refs" in use at /home/xormon/xormon-ng/server-nest/microservices/oceanstor/OCEANSTOR.pm line 1144.
Connection test is Ok for theses devices.
5300 and 6000 work fine with Stor2rrd.
Good job for the NG release, it's very pleasant.
Frédéric.
Hello Frédéric,
There was a bug:
1. Apply this fix:
https://download.xormon.com/patch/1.5-83-g84c83/OCEANSTOR.pm.gz
Gunzip it and copy to this path in your Xormon application directory (755, xormon owner):
-rwxrwxr-x 1 xormon xormon 94667 14. Aug 07.38 OCEANSTOR.pm
If your web browser gunzips it automatically then just rename it: mv OCEANSTOR.pm.gz OCEANSTOR.pm
Make sure the filesize is the same as in the example above
2.
su -l xormon
cd /home/xormon/xormon-ng/server-nest
npx pm2 restart oceanstor
3. Wait about 1 hour, then refresh xormon UI (ctrl+F5).
Let us know
Hello Lukas,
The fix is the same as file installed.
xormon@xormonng:~/xormon-ng/server-nest/microservices/oceanstor$ ls -l OCEAN*
-rwxr-xr-x 1 xormon xormon 94667 Aug 14 06:43 OCEANSTOR.pm
-rwxr-xr-x 1 xormon xormon 94667 Aug 14 06:42 OCEANSTOR.pm.orig
xormon@xormonng:~/xormon-ng/server-nest/microservices/oceanstor$ diff OCEANSTOR.pm OCEANSTOR.pm.orig
So, i have the same error in log file.
Version deployed :
XorMon 1.5.0
Node.js v20.16.0
Frontend 1.1-395-g9bc405e3
Database 2.15.2
Appliance 1.5.0
Frédéric.
Hello Frédéric,
I apologize. My mistake.
1. Apply this fix:
https://download.xormon.com/patch/1.5-100-g9e21e/OCEANSTOR.pm.gz
-rwxrwxr-x 1 xormon xormon 95008 14. Aug 11.03 OCEANSTOR.pm
2.
su -l xormon
Let us know
Thanks Lukas, it's perfect !
Metrics appear for the missing array.
Frédéric.
