I have an IBM XIV G2 and STOR2RRD will not connect: HTTP response code said error
I'm trying to connect STOR2RRD into XIV sotrage and during test:
i've error:
when I'm checking:
I received:
Please help me!
wbemcli -noverify -nl ei https://lpar2rrd:PASSWORD@X.X.X.X:5989/root/ibm:IBMTSDS_StorageSystem
i've error:
* wbemcli: Http Exception: HTTP response code said error
when I'm checking:
/usr/bin/openssl s_client -showcerts -tls1 -connect X.X.X.X:5989
I received:
CONNECTED(00000003)
depth=0 C = US, ST = NY, L = Armonk, O = IBM, OU = CIM Agent, CN = owner, emailAddress = owner@us.ibm.com
verify error:num=18:self signed certificate
verify return:1
verify error:num=10:certificate has expired
notAfter=Dec 22 20:52:31 2011 GMT
verify return:1
verify return:1
Certificate chain
0 s:/C=US/ST=NY/L=Armonk/O=IBM/OU=CIM Agent/CN=owner/emailAddress=owner@us.ibm.com
i:/C=US/ST=NY/L=Armonk/O=IBM/OU=CIM Agent/CN=owner/emailAddress=owner@us.ibm.com
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Server certificate
subject=/C=US/ST=NY/L=Armonk/O=IBM/OU=CIM Agent/CN=owner/emailAddress=owner@us.ibm.com
issuer=/C=US/ST=NY/L=Armonk/O=IBM/OU=CIM Agent/CN=owner/emailAddress=owner@us.ibm.com
No client certificate CA names sent
SSL handshake has read 761 bytes and written 353 bytes
New, TLSv1/SSLv3, Cipher is AES256-SHA
Server public key is 1024 bit
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : TLSv1
Cipher : AES256-SHA
Session-ID:
Session-ID-ctx:
Master-Key: BC3415C15B82DA6525D7D3D4E10318CB59B7C54B71D855F9E2CA2DA7AF049FA13DB006C42CAE059A9283AADC2921381D
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1479378390
Timeout : 7200 (sec)
Verify return code: 10 (certificate has expired)
Please help me!
Could you get IBM support to restart CIM service on that XIV? This is something what tend to hang but then error message looks a bit different. CIM restart can be done only be IBM remotely, you cannot do it from the storage GUI.
Thank you for your reply. Unfortunately we don't have support for this XIV anymore ...
but i'll try to ask.
