Only one Power System are displayed in UI
LPAR2RRD are configured and have been 100% operational before but now I have seen that one of the Power Systems are not shown in UI anymore.
I can successfully run connection tests for HMC servers and when I run the ./load.sh script I can see that both Power Systems are displayed, but the one mentioned below does not end up in UI.
power-json2db.pl : Inserting SERVER : XXXX104 into database
power-json2db.pl : Inserting SERVER : YYYY204 into database (this one are not shown in UI)
I can also see it is adding all LPARs (VMs) when I run the ./load.sh script, but the ones located at YYYY204 Power System are not displayed in UI.
power-json2db.pl : Inserting VM : XXXX2 into database
power-json2db.pl : Inserting VM : XXXX into database
power-json2db.pl : Inserting VM : XXXX01 into database
I have rebooted LPAR2RRD Server and waited +12h aswell.
Version : LPAR2RRD custom free version 7.80-1
send us details (server name which does not work) together with logs
Thanks! I have uploaded logs and information.
