Issue with loging
- storage firmware
- logs
- the log has been uploaded
- HPE Storage OS 3.3.2.135 (GA)+P01
Hello Ahmed,
can you try to get data from API using these curl commands below?
1) set <user>, <password>, <3par_ip_address>, <api_port> (8080 standard)
2) get api token from user and password using this curl:
curl -i -X POST \ -H "Content-Type: application/json" \ -H "Accept: application/json" \ -d '{"user":"<user>","password":"<password>"}' \ "https://<3par_ip_address>:<api_port>/api/v1/credentials"3) get value from key from previous output and use it for following curl instead of <token>
curl -i -X GET \ -H "Accept: application/json" \ -H "X-HP3PAR-WSAPI-SessionKey: <token>" \ "https://<3par_ip_address>:<api_port>/api/v1/capacity"
Are you able to get any data using these curl commands?
Can you send us output from the second one?
1- has been done
2-
if you have free time for a remote session we can do?
