Add WLC cisco Wireless LAN Controllers 5800 series
I added WLC Cisco as a LAN SW, but I cannot add it.
Dose supports the WLC 5800 (Wireless LAN Controllers)
I am not sure how much it is supported, we have never tried that.
if that does not work now it would need some adjusting in the code to make it work, we can eventually look at that if you are willing to provide us some snmp outputs
What you want, I will provide for you.
What are the SNMP outputs you need? Do you have a specific command?
