Devices added but not visible in the dashboard left menu
when have you addeed them, morevthat a hour ago?
if so, send us logs
Dashboard menu is managed manually by user. If you want to see some graphs in dashboard, add them by clicking on star icon in top right of a graph. see https://xormon.com/dashboard.php
@Pavel I have uploaded the logs. Devices have been added weeks ago.
@TomasJetelina I expect to be able to browse the left menu and find the devices, like it worked with previous versions..
left menu is per selected section in top menu
if you want to see storages in left menu, select top menu: Storage -> All Devices
Oh, thanks @TomasJetelina, it changed a bit the way of browsing devices. I will get use to it, i guess :)
