Problems to see HOSTS from HMC by RESTAPI
HI,
I've a LPAR2RRD 7.50 on a RHEL8.5 and I should connect it to a Virtual HMC V9 R2 SP950.
I ran the command to check if the hmc is visible from the server and it's OK.
#[lpar2rrd@itpd-zabbix-prd ~]$ perl /home/lpar2rrd/lpar2rrd/bin/conntest.pl 10.211.35.17 12443
#Connection to "10.211.35.17" on port "12443" is ok
So, I have correctly configured the connection parameters on the GUI, but when I click on SAVE & TEST BUTTON, I have thi reply - Connection OK but NO MANAGED SERVERS FOUND [see attach]
On HMCs I've two server that properly acquire each performances.
Could you help me?
