No RRD data for switches Brocade BR-6510
Hi,Send us logs.Note a short problem description in the text field of the upload form.
files were uploaded successfully
it looks like your switch does not provide statistics for ports.
e.g.:
tmp/MSK-TI-BR6510-100-1-perf-last.txt
-->1636542605,,,,,,,,,0,0,,,,MSK-TI-BR6510-100-1,port1.rrd,port1.rrd,0,,
1636542605,,,,,,,,,0,0,,,,MSK-TI-BR6510-100-1,port2.rrd,port2.rrd,0,,
1636542605,,,,,,,,,0,0,,,,MSK-TI-BR6510-100-1,port3.rrd,port3.rrd,0,,
Can you try the following snmpwalk commands?
1. physical port numbersnmpwalk -c <community string> -v 2c <switch IP> 1.3.6.1.4.1.1588.2.1.1.1.6.2.1.37
2. statisticssnmpwalk -c <community string> -v 2c <switch IP> 1.3.6.1.3.94.4.5.1.4
snmpwalk -c <community string> -v 2c <switch IP> 1.3.6.1.3.94.4.5.1.5
snmpwalk -c <community string> -v 2c <switch IP> 1.3.6.1.3.94.4.5.1.6
snmpwalk -c <community string> -v 2c <switch IP> 1.3.6.1.3.94.4.5.1.7Send us output (here or https://upload.stor2rrd.com). -
Hi,You're right
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.1 = STRING: "0"
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.2 = STRING: "1"
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.3 = STRING: "2"
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.4 = STRING: "3"
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.5 = STRING: "4"
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.6 = STRING: "5"
iso.3.6.1.4.1.1588.2.1.1.1.6.2.1.37.7 = STRING: "6"
....2. statisticssnmpwalk -c <community string> -v 2c <switch IP> 1.3.6.1.3.94.4.5.1.4
No Such Object available on this agent at this OID
Switch behaves very strange.
raise a ticket with your switch support.
Ask them why this switch doesn't provide statistics for ports.
And provide them output from the snmpwalk commands.
Let us know. -
>snmpconfig --enable mibCapability -mib_name FA-MIB
thanks for your help in solving this problem!
