Able to see remote LPAR2RRD but not remote STOR2RRD
Just got the Xormon virtual appliance up and running. I pointed the back end to an existing LPAR2RRD and STOR2RRD running on a different server. The Setup Connection test passed successfully for both LPAR2RRD and STOR2RRD
I can only see data from LPAR2RRD, though. I don't have any kind of Storage Tab, like I see for LPAR2RRD (the Server tab).
If I go to Settings --> Storage --> Devices, my storage device (Nimble) is displayed there, and passes the connection test.
Am I missing something?
--Jeff
--Jeff
Nevermind, I just did a manual load.sh, and the Storage tab and device showed up. So that's good...
But am I going to have to manually run the load.sh to update the data? -
hi,it works automatically, perahps you should have waited a bit
