lpar2rrd does not load
hi1. check apache logs, error_log, access_log if anything obvious (they are somewhere in .var)2. this outputls -l /var/tmp/lpar*realt*tail /var/tmp/lpar*realt*
Thank you, Pavel.I can't find how to solve these logs.Could you tell me, please?
ok, I see the problem, some corrupting in a confguration filecd /home/lpar2rrd/lpar2rrdtail -1 etc/vers*ls -l etc/web_configpls text based screenshots, no pictures
[root@xorux lpar2rrd]# tail -l etc/version.txt
6.00 2019-02-13_16:00
6.02 2019-07-11_16:31
6.10 2019-10-18_17:06
6.11 2020-01-13_18:27
7.03 2020-12-02_18:07
[root@xorux lpar2rrd]# ls -l etc/web_config/ total 36
-rw-rw-r-- 1 lpar2rrd lpar2rrd 2 Dec 2 2020 acl.json
-rw-rw-rw- 1 lpar2rrd lpar2rrd 140 Sep 25 2020 alerting.cfg
-rw-rw-r-- 1 lpar2rrd lpar2rrd 3158 May 31 10:05 config_clieck_lpar2rrd.log
-rw-rw-rw- 1 lpar2rrd lpar2rrd 60 Feb 13 2013 custom_groups.cfg
-rw-rw-r-- 1 lpar2rrd lpar2rrd 110 Dec 3 2020 dashboards.json
-rw-rw-rw- 1 lpar2rrd lpar2rrd 3844 May 31 03:56 hosts.json
-rw-rw-r-- 1 lpar2rrd lpar2rrd 263 Dec 3 2020 htusers.cfg
-rw-r--r-- 1 lpar2rrd lpar2rrd 1489 Mar 12 16:24 reporter.json
-rw-rw-rw- 1 lpar2rrd lpar2rrd 3596 Dec 3 2020 users.json
Good afternoon.
Last time the program worked, but this morning the program stopped working again, I can't understand the reason. Can you please tell me what the problem is? -
1. definitelly upgrade to the latest version 7.202. ls -l etc/web_config/
good morning. I updated the version, but the same problem reappeared today.
total 40-rw-rw-r-- 1 lpar2rrd lpar2rrd 2 Dec 2 2020 acl.json
-rw-rw-rw- 1 lpar2rrd lpar2rrd 4292 Jun 24 01:44 hosts.json
Hi,when it worked last time? before 24th of June?this list yet:ls -ltr etc/.web_config/| tail
