Problem to configure Cisco MDS
i have a problem to configure a MDS cisco, this is the problem log,
"API host network connection: UDP connection to xx.xxx.xx.xx:161 is OK
Crontab test: OK
API authorization: NOK
Wed May 5 12:38:21 2021: Got Timeout querying xx.xxx.xx.xx:161 with public for sysName. /home/lpar2rrd/stor2rrd/bin/SNMP_lib.pm:1068 :
/usr/bin/snmpwalk -v 2c -c public xx.xxx.xx.xx 1.3.6.1.2.1.1.5
SNMP version : 2c (default)
Port : 161 (default)
Timeout : 5 seconds
Community : public
STATE : NOT CONNECTED!"
have you any doc or idea for configure a MDS Cisco?
regards
regards
Hi,I suppose this does not work:/usr/bin/snmpwalk -v 2c -c public xx.xxx.xx.xx 1.3.6.1.2.1.1.5it could be about switch setup, follow this: https://stor2rrd.com/install.php#SANIs that only switch whic does not work? have you tried others?
yes snmpwalk doesn't work:/usr/bin/snmpwalk -v 2c -c public xxx.xxx.xxx.xxx 1.3.6.1.2.1.1.5Timeout: No Response from xxx.xxx.xxx.xxxshow snmp communityCommunity Group / Access context_________ ______________ _______public network-operator./bin/config_check.sh xxx.xxx.xxx.xxx
=========================SWITCH: xxx.xxx.xxx.xxx=========================UDP connection to "xxx.xxx.xxx.xxx" on port "161" is oksan_verify.pl:Mon May 17 16:53:43 2021: Got Timeout querying xxx.xxx.xxx.xxx:161 with public for sysName. /home/lpar2rrd/stor2rrd/bin/SNMP_lib.pm:1068 :snmpwalk -v 2c -c public xxx.xxx.xxx.xxx 1.3.6.1.2.1.1.5SNMP version : 2c (default)Port : 161 (default)Timeout : 5 secondsCommunity : publicSTATE : NOT CONNECTED!connection failed!!Check network connectivity and user accessNo LAN configured :perl /home/stor2rrd/stor2rrd/bin/conntest_udp.pl xxx.xxx.xxx.xxx 161UDP connection to "xxx.xxx.xxx.xxx" on port "161" is ok
I have other MSD cisco configured and works, but i didn'install them
regards
have you any news about my issue?
regards -
Hithis must work:/usr/bin/snmpwalk -v 2c -c public xx.xxx.xx.xx 1.3.6.1.2.1.1.5Check it on your other MDS.Compare settings of them, SNMP, access list ...
