Synology connectivity issue
Hi all,
Recently upgraded to
Created reference in GUI as per documentation, amd executed the connectivity from GIU
Thu Mar 11 12:45:11 2021: Got Timeout querying xx.xx.xx.xx:161 with xxxxxxxx for sysName. /home/lpar2rrd/stor2rrd/bin/SNMP_lib.pm:1001 : /usr/bin/snmpwalk -v 2c -c xxxxxxxx xx.xx.xx.xx .1.3.6.1.2.1.1.5.0 SNMP version : 2c (default) Port : 161 (default) Timeout : 5 seconds Community : xxxxxxxxx STATE : NOT CONNECTED! The device is populating in the Gui, but Pool, performance, etcetera, are empty. Please there is any workaround to resolve? Already applied deviceconntest.pm workaround without success
| STOR2RRD version 7.00 to be able to review capacity for Synology. DSM version is higher than requirement. | ||||||
| After perform connectivity test: | perl /home/stor2rrd/stor2rrd/bin/conntest_udp.pl xx.xx.xx.xx 161 | UDP connection to "xx.xx.xx.xx" on port "161" is ok |
Hi,1. enable SNMP on the storage as per dpocu: https://stor2rrd.com/Synology-monitoring.php2. is this working?perl /home/stor2rrd/stor2rrd/bin/conntest_udp.pl <your IP> 161
Thanks,
1.- Yes, It's enabled. The only difference as it's different community, as is was defiined for other purposes. I tried temporary change to "public" without success.
2.- Yes, conntest_udp.pl is working. What is not working is the API Authorization
3.- I have more than 30 devices, so I just started with 7, all with the same issue. -
test snmpwalk, but it will time out
try this as well/usr/bin/snmpwalk -v 2c -c xxxxxxxx xx.xx.xx.xx .1.3.6.1.2.1.1
what SNMP do you have enabled on the storage, just 1 and 2c? Try disable 3
Thanks again
Found 2 issues.
Command fails as per current community ends with "&".
Changed to public temporarily and got Timeout message.
Timeout: No Response from XXXXX
But the conntest_udp shows good. What can be causing that timeout? Not found any additional port to be opened as per doc -
And not V3 enabled in that system.
log a call with the vendor like "SNMP is not working"
Sure, as there is a connectivity stopper.
Once have answer from vendor will be updating the resolution
